3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
Okay, I have been playing with A-D trucks for 30 years and I still have much to learn. wink
I know from reading the shop manual that the cab mounting changed from 3-point to 4-point in 49. All I have had were 50 and later. Is it difficult to mount a 47-48 Cab on a 49-later Frame? Anyone done this, and what is the best way to do this? Thanks
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0101.htm
Professional Novice
The best way to do that would be to get the rear cab mount shackles from a '49 and later cab and install them on the earlier cab. Unless you're working on a concours restoration (probably not since you're using an "incorrect" frame wink )
I think I have the rear shackles off my '49.
I used doughnuts.
If you want, I'll look
Rick
[email protected]
Thanks guys. So far, my question is hypothetical.
Professional Novice
