2 members (2-Ton, baldeagle),
81
Mod | | | Forums66 Topics128,097 Posts1,056,495 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I want/need more speed and power in my 53. I had a 64 chevy LWB with a 230, 3speed, and 4:11 gears that was plenty powerful for me. Just some facts, my 53 it has a 235, original 3 on the tree, TT, and original rearend. It is a frame off restoration done by me. It's all original looking except for the color of paint and the wheels, no modifications, just new parts. I would like to swap the engine for a later 230 or 250 (perhaps a 292). I would like to keep the 3 on the tree though. I wouldn't mind tossing out the TT and changing the rearend. This truck is 5 day a week driver. Here's the catch, I am an amature. I have pulled and engine before, I just haven't messed around with motor mounts, crossmembers, spring perches and so on... Any tips on any swaps would be great. I know many people have done this here so any "I would do this again", "I wouldn't do it like this", "I wish I did it like this" comments would be great. I have read up on the T5 swaps and that may easily be a possibility since my 235 really doesnt run bad (..and I have 5 other 235's and 216's laying around). Thanks Much! | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | What I'd do is try to rebuild it to squeeze more power out of it. Hot Rod mag did an interesting article on that a few months back. If you can get something with more of a stroke and more displacement, like that 292, I'd do that.
In fact, an EFI system might be perfect for one of these engines.
Anyway, I would think the other engines would bolt right in place of your 235. But maybe you should have a knowledgeable machinist rebuild one of your engines for you. Try to use newer technology parts if you can. I hear you can rebuild these things for about 300 hp, which really would make a difference in seat of the pants feel.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | chuckthe,
Your site is a "must see" for anyone working on these trucks. Great pictures and detailed instructions on all the aspects of a rebuild...funny too!
Stuart | | | | | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | Have you thought about building a 261? The swap would be pretty much a direct bolt. Putting in a modern six is just as difficult as putting in a small block. A 261 with a mild cam, 4 barrel, headers, a little port work, and bumped up compression would run ya along pretty good. It would fit snug as a bug in a rug, and look really original.
Boo
We don't need no stinking V-8s!!
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks Guys! I have looked at chucks website a few times and it has always been a good resource. I am going through it again and am on page 18. Boo, the thought has crossed my mind and if I came across one I would probably go that route. But then again, swapping to a 261 doesn't get me any more speed. Thanks for all the input though! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Boo Radley: Putting in a modern six is just as difficult as putting in a small block. Well not quite. A modern six has all the bellhousing, clutch and mount issues, but not the steering interference issue. I like the 261 for this one too, though a 270 or 302 GMC would be options also, but keep in mind the front mount issue with a GMC and radiator clearance issues of either the GMC or any '55 or later Chevy motor.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Actually, it would be very simple to get a wider modern truck radiator and mount it right behind the grill, if you wanted more room in the front of the motor. The sheetmetal contour behind the grill makes a very nice start for a fabbed-up fan shroud too.
That's what I plan to do when I convert to a V8.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Mine is a GMC, but its a canadian model so I am not sure if it has more room then the chevys since the GMC's had Chevy engines up here. Not many 270's or 302's around here as far as I know since, again, GMC's had chevy engines. I guess that speed Is a greater priority then power at first. I forgot to mention that I also have a 60 GMC SWB with a good 235, 4 speed, and open rearend (3.90 I think). Would it be worthwhile to put this tranny and rear end in my 53? Would I get more speed? or would it be a pain since I think it has the hydraulic clutch? or should I find another 3 speed with an open yoke? (I'm just throwing out ideas because I need to do something) Thanks for all the input! I'm very grateful. | | |
