3 members (dt235sd, 3B, Goach2),
62
Mod | | | Forums66 Topics128,213 Posts1,057,485 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Short story long. When lit'l bro and I go to Montrose Co hunting we pull a '96 goosenect cargo trailer that's been converted into a backwoods boondocking hunting trailer/camper. Insulated walls and ceiling, running water, shower, kitchen with stove and sink, shelves for food and fully wired. It's really a comfortable way to rough it and has room to haul 3, 4-wheelers along with all the gear for 3 on a two week trip.
Well, the downside is the trailer's only pulled this one outing a year so tires are about 15 years old now and not road worthy. The solution is to swap the always late model tires off the wife's horse trailer (235/85/16's) to the hunting trailer. Of course she doesn't sit home while we're gone so I put the tires from the 3600 (215/85/18 E rated) on her trailer. Then temporarily put the hunting trailers old tires on the '51 so I can move it around. Little Bro usually helps with this little exercise.
We got back from this years hunt last Friday and I decided on Sunday to put all the tires back where they belong. Using the "while I'm in there" philosophy with the 3600 I decided this would be a good time to pull the left front hub and install one of the nos inner wheel bearing I'd just scored on Ebay. We were already in the shop, wheel bearing on the shelf and I'd tweeked my 3 jaw puller and felt I'd be successful this time in pulling the hub (not the case last year, couldn't get it off). My firm belief was the inner bearing had been cooked on a trip when the wheel locked up due to a brake issue which to my feeble brain was why I couldn't pull the hub. But that's another story for another day.
Got the front hub off, no drama this time. Inner bearing was great, so much for my theorizing. But the leading brake shoe was getting very thin and I just happened to have two new shoes in a box out of sight. Don't ask why, I don't remember. Since the rear shoe was good I changed the worn shoe and buttoned up that side, proper tire back on and all.
Now to the right front, I did ponder for several minutes but finally decided I had to at least check the shoes since I was almost in there. A few minutes later I saw both shoes looked as they should. Drum back on and now to adjust, front adjuster Won't turn. Back off comes the drum, adjuster on the front of the Huck wheel cylinder is totally frozen, rear seal is just showing the slightest of dampness. Dang!
Leaving the brake cylinder in place, pull rear seal, find slight shallow longitudinal wear marks. Work front seal out the rear opening with small thin screwdrivers, looks great. Next drive the front piston out with a short 3/4" diameter rod and bfh. Dang again, early signs of brake fluid needing to be changed with slight build up of gunk, but no major corrosion. I did manage to find my old two stone brake cylinder hone and honed the cylinder till it was clean and shinny.
Being this was Sunday afternoon I knew there was no way I'd find the 1.25 cups to do a proper repair and besides it's a hour turnaround to town. So a bit of 400 sand paper to remove the scaring on the seal followed up with 800, then 1200 grit and it looked very acceptable.
Reassembled with the cups swapped just for good measure.
Now it's obvious I've behind on changing brake fluid since it'd been 4 years and I did have a unopened quart of Dot 4 fluid on the shelf. I persuaded the wife to help with the pumping duties and we proceeded to bled and adjust all the wheels.
Well, that's done. It was late in the day (as in almost dark) but I did finish the tire swapping detail and everything was finally put away in it's proper hay shed storage spot.
Once again, a fairly small project morphs into a much bigger deal. When will I learn, on yeah, never.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Very entertaining but now I need a nap, your activities wore me out.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Ron, you should have been in my shoes. I'm still trying to find time to rest up.
RonR
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Buy some new tires for the trailer. Never succumb to the "while I'm here" temptation. (easier said than done. BTDT)
SimS | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
| | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | It's always amazing how some simple job will turn into a major project before you're done. | | | | | Joined: Mar 2007 Posts: 3,458 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,458 | I have a tendency to over think things once in a while, that usually my first step towards "while I'm here". The rest is just as you say morphed into something bigger.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | A long time ago, Barry Weeks coined a term for it -- "Progressive Sublimation" (or something like that ...). You go out to the shop to do one little chore before breakfast ... but ... the next thing you know, its 5 pm, you have crap (that you hadn't planned on doing) spread out all over the shop, and you gotten involved in a lot of work (you're tired and dirty) EXCEPT what you originally went out to do. Happens to me all the time.
Craig -- know what you mean. I have "shoot on sight" orders for the two most evil entities I can think of ... the Good Idea Fairy and the "While I'm At It" Fairy ... Both of them have caused quite a lot of mayhem in my life ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2007 Posts: 3,458 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,458 | There's a bounty on the "Good Idea Fairy" in So Ga, He shows up in his 67' F*#d and puts my tools away...
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Barry Weeks - a name well-known to many of us.
In 2018, he had a thread about a mistaken identity. No other posts since 2011.
Barry was always knowledgeable and clear/correct, and very helpful. | | |
