the passenger door key lock for the door will turn to the unlock direction but when i try to lock the door it will not budge, in fact i bent the key attempting to lock it, so i stopped before it broke. it locked effortlessly before. where should i start?
also, the door handles sag down a little, is this normal or is there a fix?
