| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | the passenger door key lock for the door will turn to the unlock direction but when i try to lock the door it will not budge, in fact i bent the key attempting to lock it, so i stopped before it broke. it locked effortlessly before. where should i start? also, the door handles sag down a little, is this normal or is there a fix?
Owner of the most temperamental 1951 3100 in existence
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Something may be jammed in the door latch mechanism that's preventing the lock from turning. You can remove the lock cylinder fairly easily by pulling the flat metal clip at the rear of the door edge. If the key turns once you have the cylinder out then the door latch mechanism is at fault. you'll probably need to remove the latch to check that.
Sagging door handles are a common problem. Most of the vendors sell replacement springs as a fix.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | will do. thanks for the info!
