3 members (Lightholder's Dad, 2 invisible),
81
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 27 | Hey guys,
I recently installed a heater in my 53 Chevy Pick up. I drained the radiator, and installed a new 180 deg thermostat.
Since then, the org. gauge shot up over 220, and eventually broke the gauge. I installed a temporary gauge and see that when I first run the engine it shoots up past 240 degs and then will shoot back down to right around 180. While driving it will go up to about 220 before the thermostat opens up.
I first thought it might be an air pocket, but I did burp the system ( at least I thought I did.. by leaving the cap off until I got some fluid coming out of the top radiator then placed the cap back on). But the temp gauge still shoots before the Thermostat opens up.
Also, the thermostat that I purchased already had a pre-drilled hole in it (with a little brass jiggly thing in it), so I thought that hole would be enough. Perhaps another hole?
Anyone have thoughts about what would be causing the thermostat to not open up until the temp gets much hotter then it should?
-James
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Sounds like a faulty thermostat to me. If you have a thermometer you can put it in a pan of water on the stove and monitor at what temp it starts to open.
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | You may already know this, but a thermostat does not establish the top range of temperature your engine will run at...it establishes the lowest temp your engine will run at. I find that confuses some folks. I'd buy a 160 degree thermostat and go with it. If you are tempted to purchase one of the thermostats sold under the name "Fail Safe" please consider another brand. If your engine ever overheats---even once, that thermostat is forever disabled and left in the open position.
If you put a 180 degree thermostat in a pan of hot water with a candy thermometer, you'll see it starts to open at 180...just a crack and it may even be hard to see it is doing anything. It won't get fully open until around 220~230 and that's what yours is doing. I don't see any reason to run a 235 at 200 degrees or more and neither did the guys who designed it. Good luck!
Side note: a year ago I tested 4 different makes of thermostats (all 160 degrees) to see if they were all about the same. No dice. Two of them didn't begin opening until 180 so I assume they were either defective or marked incorrectly in the country of their manufacture (which was not the USA).
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jul 2000 Posts: 2,208 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,208 | I have a 180 deg thermostat and it works just fine. I did have a problem with erratic water temps earlier this year and it had to do with heater hose routing. I had to add a bypass.
Your problem started after you installed a heater (and new thermostat) - did you replace the old heater or is this a completely new install?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2014 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 27 | Well technically yes the problem did start after I installed a new heater (never had one before). However, that is when I found out my father in law who owned the truck decided it was best to remove the Thermostat and hadn't had one in the truck for years. When I was installing the heater I purchased a 180 deg thermostat, thinking I would swamp out the 160 deg one, but when I opened up the housing, there was no thermostat. Thats when he mentioned he would always have problems with the thermostat being stuck closed. So I may have stumbled on a pre-existing issue that he never solved and left it to me to stumble across.
| | | | | Joined: Jul 2000 Posts: 2,208 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,208 | I would put the heater hose plumbing back to the way it was before you installed the heater and test to see how it runs. The idea is to only change one thing at a time to make it easier to diagnose the problem. If it still overheats, you have narrowed it down to the thermostat area and you can do the cook it on the stove test as Jon suggested. If it doesn't overheat, you know the thermostat is ok and something is wrong with the heater installation.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a defective therm. or it is in up-side down. About 1/3 of the new thermostats we get are defective. Most therms go up a little higher before they open & then go back to the running temp. Yours is way to high. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I just put in a high flow 180 thermostat in my 54. It did not get warm enough in the winter with a 160 but I drove it today 33 degrees with the 180 and it got toasty in the truck. It says offroad and racing only. Got it at Auto Zone.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
