7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible), 105 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#1323188 08/23/2019 9:14 PM
I'm aiming at putting the bed on my 53 one ton Sunday, and I'm wondering about the long mounting bolts. I've been told they go in the front cross sill, but I don't see how they could fit. Are there supposed to be holes in the bottom of the frame, so that they go all the way through? I don't have those holes on my frame, and it looks like the long bolts will run into the frame. This truck had a bed on it when I got it, so it must have been held on somehow. All the other bolts are shorter, and seem to be just long enough to go through the bed, cross sill, wooden block, and the top of the frame.
Am I just really confused?
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Mar-K describes the 12” bolts installing that way, my 3/4-ton went together as they describe, they go all the way through. I am unsure why you would not have the same holes?
My 3/4 ton gmc only had the hole drilled through the bottom of the frame on one side only. Drivers side i just used a shorter carriage bolt.
