| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | A few years ago, I had read somewhere (here?) that adding rubber bushings between body and frame of a TF truck really helps comfort and road noise, NVH, the OEM calls it! Someone was even saying that pieces of rubber cut from a tire worked well! I have a '57 Suburban, and I am still thinking it could be a good idea, so I have a couple of questions: Is it really worth it? Does it really help with vibrations, noises...? (I cannot see how it would not help, but...). Using old tire bits seems a bit rustic, I would rather do it well and use real rubber bushings, anyone knows what size I would need (diameter, height) by any chance; I prefer to have the parts handy before I take my truck apart... I bet I would need new bolts, too. Is it a horribly difficult job? Anyone has advice, ideas... that would help? I am not taking the body off the frame for a restoration, just lifting it enough to add bushings. Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Really? No one has any idea? Or even better, no one has ever done that?
| | | | | Joined: Mar 2007 Posts: 3,383 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,383 | I purchased a cab mount kit for my 59' from Brothers Truck ( https://www.brotherstrucks.com) that has rubber body mounts. I'm not sure if they carry a kit for a Suburban, if not it shouldn't be that difficult to adapt a truck cab mount for your needs. he kit came with all new hardware as well. Good luck.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I purchased a cab mount kit for my 59' from Brothers Truck ( https://www.brotherstrucks.com) that has rubber body mounts. I'm not sure if they carry a kit for a Suburban, if not it shouldn't be that difficult to adapt a truck cab mount for your needs. he kit came with all new hardware as well. Good luck. Thanks, I have heard about those, but if I not wrong, they are very thin, very hard rubber squares used only to prevent metal-to-metal contact between body and frame, they are not there for noise and vibrations. I was thinking going thicker body bushings.
