0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 22 Apprentice | | Apprentice Joined: May 2005 Posts: 22 | I am installing a roll pan on the back on my 61 Chevy C10 (stepside). I want to remove the original tail lights and reverse lights and install some flush mounted lights cut into the roll pan, anyone know of a good set on the market or some other options?
JS | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i don't know if you have a rolled top edge on your bed but i put lights in the bed roll to get an uncluttered look. i also put led strip lights between the bed and roll pan, they can be used both as a stop light and and turnsignals.. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Where did you buy your bed roll lights? less than $80? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | GAZIM, i got the lights at www.pros-pick.com for 74.00 and plus 15.00 ups charges on 8/31/2004. they are called hot lite'z. they are located in canada. RON
| | | | | Joined: May 2005 Posts: 22 Apprentice | | Apprentice Joined: May 2005 Posts: 22 | WE b OLD, I already purchased the hot lite'z and plan to install them also, but I want a set of flush mounts with the reverse light built in. The led sounds interesting. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i looked into the high mounted stop lights on chevy and ford trucks some have what you are looking for. i don't have the welding skills to do the work so i opted for the LED strip lights, i get a lot of postive feed back from people who see them. ron
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to www.rbsauto.com, they have a nice selection of lights. ron
