Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Hotrod Lincoln, Phak1, Bristol's Tree S, DoubleB), 141 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
Junior Member
Junior Member
Hey everyone. does anyone know how to find out the stall speed of any given GM torque converter? I have a 350ci/ TH-350 in my 36 chevy and a couple different torque converters... I'd like to know what I've got before I wedge it in between my engine & trans. thanks ~Mykk
The stall RPM on my aftermarket converter is stamped on it. Stock converters are usually rated around 1800 RPM.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
' Offline
Keep in mind Hot rod that the torque converter must be compatible with your application. I mean what did it come out of originally, I'm told that if it came out of a 3 ton piece of iron and you are putting it in something considerably lighter or heavier? that it might make a large difference in your stall! I'm a mechanic, a young one though but I think my statement is correct. take care.
Scott
1 Offline
you are correct. engine output, gearing, and vehicle weight all affect the stall speed. that is why they are normally listed with a range not just a single rpm point.
2003 ford lightning
1959 chevy 36
