| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | I have found that when the E brake is applied in my new to me 1951 Chevy 4400, I can still rotate the propeller shaft by hand (rear axle on blocks and rear wheels off the ground) or turn the rear wheels by hand so the brake is not engaging. I have looked in the service manual and while they do have a few paragraphs on the brake with a photo, it just says to adjust it. The photo shows two adjustment locations id's as parts A,B,C and d but does not reference those lettered parts in the text. My guess is that I need to adjust the nut(s) on the larger vertical threaded rod to increase the brake shoe engagement. Am I guessing right? Thanks for the help!
1950 3600 1951 4400 Gazz
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 |
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | Thanks for that! I didn't want to screw up but looks like that is what I have to do ;-).
