0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
#1330094 10/16/2019 2:34 AM
I'm sure this has been asked before, but are 7.00 x 17 tires still being produced (looking for knobby/off road for NAPCO)? I've found 7.5 x 17 and 7.00 x 16 but no 7.00 x 17. Will any of these fit on my 7.00 x 17 rims?
Thanks in advance for any info or advice.
-Scott
Crusty Old Sarge
Crusty Old Sarge
A 7.50 will fit your wheels with no problems, Coker tire has a good selection of Bias Ply truck tires (https://www.cokertire.com/tires/styles/military-and-truck.html?p=9) If you want a better ride you may want yo look at going to a radial tire.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Thank you, that's what I was thinking, but wanted to make sure.
I agree that a 7.50-17 should fit your rim but you should also confirm with the recommend rim width for your chosen tire.
Your rim is not 7” wide, it has that wide a tire on it now. The rim is more like 5” or so, measure inside the bead seat to find out.
•1952 Chevrolet 3800 pickup
---All pictures---
Ok, thanks for the additional info.
On my '46 1.5 ton, I tried to run a more readily available wider tire/rim on the rear and the tires rubbed frame, I had to shim the tires out with a steel spacer I machined. That truck is mostly driven around the farm and on very short low speed trips. This truck I plan on using much more, so I want to make sure I get new & correct tires on it.
Cool truck, btw. Congrats!
Professional Novice
Another '59 is always cool. And a NAPCO one at that.
Rustbucket Ranch
Rustbucket Ranch
A 1-ton Napco, think I'm in love! big_eek
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
