8 members (wilbur53, mason86, ndkid275, Otto Skorzeny, 32Fordpuchoptop, klhansen, Hotrod Lincoln, 1 invisible),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | A FRIEND HAS A 1965 CHEVY 1/2 TON. HE ASK ME WHAT YEAR OF FRONT END WILL BOLT IN ON THIS... I DO NOT KNOW THIS... HE WANT'S P/S & DISC BRAKE'S SO GUY'S GIVE ME SOME INFO.....
THANK'S
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | 73 to 87 chevy stuff will bolt right on.2 or 3 ways you can go you can chnge just the spindles by changing ball joints to later model or you can change out control arms and all.you must use the 73 to 87 steering idler arm also or you will have problems with the steering geometry. | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | 73 to 87 chevy stuff will bolt right on.2 or 3 ways you can go you can chnge just the spindles by changing ball joints to later model or you can change out control arms and all.you must use the 73 to 87 steering idler arm also or you will have problems with the steering geometry. | | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | V6 JIMMY -- THANKS FOR THE INFO. I WILL PASS THAT ON...
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | |
