1 members (walter74),
75
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I picked up an under dash mount AC setup and it came with a square-type York compressor. I want to mount it on a small block V-8 (327). Does anyone make a mounting bracket for this style of compressor for small block V-8? Otherwise, if anyone has a York compressor on a V-8, can you post or email photos so I can see what to look for at a swap meet? Thanks for the help.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Look up and contact Alan Grove Products...they make engine brackets for just about everything you can think of. Mike B  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The York & Tocumseh compressors use the same mounting system & the mountings are interchangeable. One is aluminum & one is cast iron. I have forgotten which is which. It seems there should be some of these around the old salvage yards. All the aftermarket A/C units used them. They will be for the short water pump though. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Kerwin, is it an aftermarket A/C system that was common in the 50s-60s? Lots of dealers installed them in their shops, as well as repair shops and garages. Does it have a brand name on it? Do you know what it came out of? What do you plan to use it in?
Once I saw an eBay truck, 54 Chevy if I remember correctly, that had an underdash A/C system on it. Maybe someone posted a picture of it on Stovebolt... years ago. Sorry, not necessarily germane to this discussion.
Professional Novice
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have a 65 in the shop right now that had a York on a sbc. The compressor and brackets are in the bed but I could snap some pix if desired. The owner probably has no more use for the setup as he is going with the Sanden compressor on the new engine. It's pretty obvious where the brackets fit on the engine if it is all still bolted together.
Evan
| | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Some pics would be great. Would the owner just sell the brackets?
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | It's a Monitor Mark IV aftermarket system that I picked up to use on my 57 Chevy sedan. Pretty neat under dash unit that will look good in the 57. I will probably just go with a newer compressor if I can't easily find brackets for this York. Might just hold onto the York for adding onboard compressed air when I get back to my 59 1-ton project. Thanks!
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Sorry, it's been canabalized. Looks like the only part left is the compressor and the bracket that holds the idler pulleys. We have a very big shop and everyone in the area knows we are taking off old parts so they're like a crowd of buzzards waiting to pounce. [img]https://i.postimg.cc/06YydPfr/IMG-4945.jpg[/img]
Evan
