3 members (Peggy M, Otto Skorzeny, Ponchogl), 87 guests, and 1 robot.
Topics128,052
Posts1,055,729
I picked up an under dash mount AC setup and it came with a square-type York compressor. I want to mount it on a small block V-8 (327). Does anyone make a mounting bracket for this style of compressor for small block V-8? Otherwise, if anyone has a York compressor on a V-8, can you post or email photos so I can see what to look for at a swap meet? Thanks for the help.
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
Look up and contact Alan Grove Products...they make engine brackets for just about everything you can think of.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Riding in the Passing Lane
The York & Tocumseh compressors use the same mounting system & the mountings are interchangeable. One is aluminum & one is cast iron. I have forgotten which is which. It seems there should be some of these around the old salvage yards. All the aftermarket A/C units used them. They will be for the short water pump though.
George
1972 Chevy c10 Cheyenne Super
Kerwin, is it an aftermarket A/C system that was common in the 50s-60s? Lots of dealers installed them in their shops, as well as repair shops and garages. Does it have a brand name on it? Do you know what it came out of? What do you plan to use it in?
Once I saw an eBay truck, 54 Chevy if I remember correctly, that had an underdash A/C system on it. Maybe someone posted a picture of it on Stovebolt... years ago. Sorry, not necessarily germane to this discussion.
Professional Novice
We have a 65 in the shop right now that had a York on a sbc. The compressor and brackets are in the bed but I could snap some pix if desired. The owner probably has no more use for the setup as he is going with the Sanden compressor on the new engine. It's pretty obvious where the brackets fit on the engine if it is all still bolted together.
Evan
Some pics would be great. Would the owner just sell the brackets?
It's a Monitor Mark IV aftermarket system that I picked up to use on my 57 Chevy sedan. Pretty neat under dash unit that will look good in the 57. I will probably just go with a newer compressor if I can't easily find brackets for this York. Might just hold onto the York for adding onboard compressed air when I get back to my 59 1-ton project. Thanks!
Sorry, it's been canabalized. Looks like the only part left is the compressor and the bracket that holds the idler pulleys. We have a very big shop and everyone in the area knows we are taking off old parts so they're like a crowd of buzzards waiting to pounce.
[img]https://i.postimg.cc/06YydPfr/IMG-4945.jpg[/img]
Evan
