4 members (55shaker, Shade Baby, GMCJammer51, joe apple), 86 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#1328796 10/04/2019 10:34 PM
on my 1948 6400 , I installed a new master cylinder. When I let off the brake petal, the brakes won't completely release. I loosened the brake line coming out of the master cylinder . That relieved the pressure, brakes were free. . So I removed the little valve inside the master cylinder . didn't help. Brakes only reliese when I bleed the line coming out the master cylinder. now what?
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Must be a bad new master cylinder. Its like there is a check valve in that outlet holding the pressure.
I would also think M/C is at fault..
Shorten the master cylinder push rod, until the piston can move back far enough to clear the bleed hole in the bottom of the resevour. If the rod is too long, exactly what you describe happens. There should be a small fountian of brake fluid in the master when the pedal is pushed. Pressure in the master needs somewhere to go when the pedal is released, the bleed hole provides that and allows fluid into the master to compensate for shoe wear.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
thanks!
3B Online: Content
3 Online: Content
Hy Charles Pretzer, in addition to adjusting the pushrod to the correct length so the master cylinder piston can return to its at rest position I would strongly recommend reinstalling the residual pressure valve you removed from your master cylinder, that will allow the hydraulic system to operate as it was designed to, hope that helps.
Thanks to all. adjusted pushrod, that fixed the problem . I'll reinstall the valve this P.M.
Sorry, I forgot you had pulled that valve out, yes for sure reinstall it.
Mac :{)
