5 members (walter74, Greg_H, Phak1, Otto Skorzeny, 1 invisible), 138 guests, and 1 robot.
Topics128,129
Posts1,056,361
Members48,441
#1271431 07/06/2018 6:48 PM
Has anyone done this? I need some guidance on my project.
This is what I did.
My Blog
Dave, thank you, I'm going to look at a 37-39 truck transmission tomorrow I located, I've got a 1940 bell housing as well, and that's what my 216 is out of
Moderated
Moderated
I am looking at pulling my 194 out and replacing it, any tips you want to share.
What are you thinking of replacing it with?
My Blog
Check your title VIN against the engine serial number...most States used the engine serial number on the title back then.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
This swap has been done quite a lot as the old motors can be difficult to rebuild. An old time friend did this swap some years back in a '30 roadster. Used 38 trans, bellhousing and crossmember and I believe a 216, without the 38 crossmember I think you will need to modify your existing crossmember and or pan. Also I have a tech article on this I can mail to you or scan, just PM me you email.
There is a shop near Merced that has a 30 coupe with 235 motor done but not in car, the shop owner is very busy and can be difficult to contact.
1946 1/2-Ton Chevy
