1 members (Hotrod Lincoln),
77
Mod | | | Forums66 Topics128,271 Posts1,058,312 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 1 Moderated | | Moderated Joined: Sep 2018 Posts: 1 | Anyone out there have the double cable bracket (throttle and choke) for a Carter YF 2100s?
Mark kline
| | | | | Joined: Mar 2014 Posts: 4,520 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,520 | These are devilish difficult to find. In the group of Rochester parts I offered for sale a month or two ago there is one of those 2 cable brackets for Rochester carbs. It might work or be able to be modified for the Carter, but I'm not interested in breaking the Rochester parts group up into parts. I'll see if I can bump that up to the top.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Jon, Does a YF 966S use the same bracket or different than 2100s ? I am looking for that bracket too.
1950 Chevy 3100
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I have both a 2100S and a 966S and the brackets appear identical to me. In fact the carbs look pretty much identical. In this earlier thread Jon listed the internal differences. https://www.stovebolt.com/ubbthread...ew/1/questions-on-carter-yf.html#UNREAD. In that same thread a list of what carbs were used on what years is posted. That list was produced by Carbking and has been widely reproduced in many threads. Unfortunately it is in error regarding the 966S which lists it as an autochoke model. It lists a 967S as manual choke. The 966S is the manual choke model. I tried to sell my 966S carb and the potential buyers used that list to tell me I didn't have a correct carb. | | | | | Joined: Mar 2014 Posts: 4,520 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,520 | As far as I know the 966s and 2100s used the same bracket. I'm also pretty certain you could adapt the Rochester bracket to work. I'm traveling now but will be happy to check that when I return.
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I've used the Rochester bracket on both the 966s and 2100s. It works fine. https://photos.app.goo.gl/2Nb5E8rDGQennfSm6
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Great Information MarkT Thank you.
1950 Chevy 3100
| | | | | Joined: Nov 2002 Posts: 2,782 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,782 | I have both a 2100S and a 966S and the brackets appear identical to me. In fact the carbs look pretty much identical. In this earlier thread Jon listed the internal differences. https://www.stovebolt.com/ubbthread...ew/1/questions-on-carter-yf.html#UNREAD. In that same thread a list of what carbs were used on what years is posted. That list was produced by Carbking and has been widely reproduced in many threads. Unfortunately it is in error regarding the 966S which lists it as an autochoke model. It lists a 967S as manual choke. The 966S is the manual choke model. I tried to sell my 966S carb and the potential buyers used that list to tell me I didn't have a correct carb. Chuck - I checked and double checked the information when I made the list. And I should have triple checked  The corrected list is available on my website at: Chevrolet YF carburetorsI apologize for any problems the mistake may have caused. Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
