8 members (Mather, KEVINSKI, TUTS 59, DBJ71SuperCustom, Gray_Ghost, Lightholder's Dad, Otto Skorzeny, 1 invisible), 146 guests, and 2 robots.
Topics128,080
Posts1,056,291
Members48,441
#1327823 09/26/2019 1:52 PM
I was talking to a guy with a 53 chev and a 235 , seems his engine would would have water in the oil after being parked for some time outside.
The leak was traced to a leak around some fitting on the hood that allowed water to drip on the valve cover which had 4 slots in the top I guess for breathing purposes.
He replaced valve cover which solved the problem.
This might not be news to some , but it was to me!
good planning is no substitute for dumb luck
panel fan #1327826 09/26/2019 2:47 PM
AD Addict & Tinkerer
The slots work in conjunction with the road draft tube to evacuate combustible vapors from the crankcase. The slots draw in fresh air and the road draft tube provides the vacuum.
As long as the replacement valve cover has a breather on the fill cap all is good. It the cap is not of the breather type, it could cause engine oil contamination, sludge build-up, oil leaks, high fuel consumption, and other engine-damaging problems.
If it was me, I would have fixed the leak!
Phil
Project Journals
Stovebolt Gallery Forum
panel fan #1327862 09/26/2019 9:27 PM
I agree on fixing the leak but not my call. and yes he used a breather fill cap.
panel fan #1328061 09/29/2019 2:14 AM
His fix is sound. "Bob's his uncle," as they say. (I will let John explain what that means. He is Canadian, and a good fellow to boot.)
No more rain in the valve cover and no more road dirt sucked into the engine.
Carl
52Carl #1329138 10/07/2019 5:54 PM
Carl
So nobody explained what “Bob’s his Uncle,” is all about. You got my curiosity! Can you explain?
Phil
Project Journals
panel fan #1329140 10/07/2019 6:06 PM
That British phrase, as I recall it, is "Bob's Your Uncle" (you're all set - no problem).
