7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13271 06/09/2003 1:43 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I did a search and came up with nothing although I thought I had read something here. What was the recommended lubricant for the steering gear box on our trucks. Restoration Supply has everything from 90 to 1200 weight and they recommend the 1200. Any thoughts or experience? Thanks | | |
#13272 06/09/2003 3:06 PM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | Try GM steering gear lube in the 10oz tube, part number 1052182.
Rick | | |
#13273 06/09/2003 5:40 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | If you can find that GM lube, you are very lucky. American Classic used to have it, but I believe they are out. The problem is GM has discontinued that item. I used Penrite steering box lube, you can get it from Restoration Supply in Reno. So far no leaks. | | |
#13274 06/09/2003 6:37 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also use chassis grease, preferably the moly base, which doesn't harden as much when it gets cold as the lithium base. In a freshly rebuilt box, the SAE 90 gear lube will work, but in a worn box the gear lube will leak out.
Fred 52 3600 69 C-10
#13275 06/09/2003 9:03 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I also use the Penrite Steering Lube . It is very thick , like semi fluid grease ,, works great and stays in the box.  | | |
#13276 06/10/2003 3:32 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Thanks for the replys. I ordered the Penrite Steering Lube today. They have some neat stuff in their catalog. | | |
