3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#13271 06/09/2003 1:43 PM
I did a search and came up with nothing although I thought I had read something here. What was the recommended lubricant for the steering gear box on our trucks. Restoration Supply has everything from 90 to 1200 weight and they recommend the 1200. Any thoughts or experience? Thanks
Try GM steering gear lube in the 10oz tube, part number 1052182.
Rick
If you can find that GM lube, you are very lucky. American Classic used to have it, but I believe they are out. The problem is GM has discontinued that item. I used Penrite steering box lube, you can get it from Restoration Supply in Reno. So far no leaks.
You can also use chassis grease, preferably the moly base, which doesn't harden as much when it gets cold as the lithium base. In a freshly rebuilt box, the SAE 90 gear lube will work, but in a worn box the gear lube will leak out.
Fred
52 3600
69 C-10
I also use the Penrite Steering Lube . It is very thick , like semi fluid grease ,, works great and stays in the box. smile
Thanks for the replys. I ordered the Penrite Steering Lube today. They have some neat stuff in their catalog.
