4 members (Gdads51, Rustnut, Otto Skorzeny, 3800GUY), 96 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
Hello,
So one of my shortlist goals for my 48' 1/2 ton is to just replace all wiring but keep 6 volt system.
I'm shopping for harnesses specific to the truck, and I've come across a lot of variation in prices.
Has anyone actually installed this harness from Classic-Parts, and if so, how were the instructions and labeling for you?
I guess the only extra lighting I'm looking to do, is run a wire to the original spot-light on drivers side. Everything else stock and no radio.
Thanks Steve
1948 1/2 Ton 6-volt 216
Here are add details...
I installed one about 6 months ago. The instructions do leave a few things for figuring out. It's basically a "wire by number", but not all the wire numbers are in the instructions. You can figure it out by using some basic deduction, but it can be a little frustrating. In the end it took me only a day and everything turned out great. I would recommend that harness personally based on the low cost and end result.
Greg Brown
If you decide to get it and have any questions, I can assist you.
Greg Brown
Thanks Gregg, appreciate it...the price is what attracted me. Glad to know it worked for you. Planning to purchase Next week.
Crusing in the Passing Lane
Don't forget, if one gets a 12 volt harness it will work fine on a 12 volt system, however, a 6 volt system requires thicker wires, so beware.
Ed
Thanks Ed, Good call out...going for just the original 6 volt replacement.
