0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
#132644 07/01/2005 7:22 AM
Junior Member
Junior Member
I just picked up a 54 gmc 1/2 ton, i was wondering if anybody has ever flipped the front axle over to the top of the leaf springs in the front end to lower the truck, I'm on a tight budget, or if anybody knows how to stretch the axle properly.
#132645 07/01/2005 12:46 PM
When I bought my truck someone had "attempted" to flip the axle over the leaf springs. The steering would bind and there was less than an inch of travel between between the axle and the oil pan. I took it apart and had the axle dropped. Removing some of the leaf springs or a dropped axle is a better solution.
#132646 07/01/2005 6:49 PM
I did that on a 1932 Chevy coupy back in the early '50's. Took a while to fix all the problems with steering, rebound clearance, shocks, etc. It did lower it a lot though. Now I use late IFS fronts and Corvette rear ends.
#132647 07/04/2005 5:44 AM
My dad told me a story about this guy that fliped his axle over and turned it around and left it on the bottom of the sprimgs, therfore raising the truck up. did i mention i am from texas
#132648 07/05/2005 9:32 AM
I'd love to have been there when the guy took it down to get it aligned. Seems to me that'd screw the alignment up in about 3 different directions. I think if I was gonna raise one up,I'd just put a four wheel drive front end under it;then all I'd have to do is add a transfer case and a couple of drivelines and It'd be useful as well as different.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#132649 07/13/2005 5:24 PM
Junior Member
Junior Member
to lower the front of my 36 chevy truck I had thought about flipping the front axle. But I physically didnt have enough room in between the axle and frame rails.(my front axle is from a 56' chevy) so instead I took apart the front leaf springs and assembled them in reverse so now the smaller leaf springs are on top instead of the bottom. it lowered the front end drastically. I put 3" lowering blocks in between the rear end and the leafs in the rear and the truck came out level... thank god. I decided not to flip the leafs around in the rear because of torque squat. check out before & after pictures on my website. www.mykkhannan.bravehost.com/projects.html
