| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 67 | Will a 47-53 Chevy truck grille out of a 1 1/2ton fit in a 1/2 truck? and what about the doors and the frount finders,Will thay fit a 1/2 ton truck? Thanks SlickT | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Only the cab parts will interchange. The fenders and grill are wider to accomodate the larger wheels and tires. So, no on the fenders and grill and yes to the doors, Scott | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Sooooooo you CAN(?)use the grill bars from a bigger truck (1 ton or larger) to fit on the 1/2 ton trucks??...inquiring minds would like to know... :confused: :confused: :confused: | | |
