| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | good morning to all, a while back, my son and i were on a weekend cruise to visit my brother about 60 miles away in 100^ weather. we get to his house, pick him up for lunch and noticed that second gear was hard to get into. ok, we get to restaraunt and park the truck because now all gears are hard to engage. we eat hoping it needs to cool off, we get in and the truck shifts fine when not running but as soon as we start it the truck jumps like the clutch isnt engaged. we towed it home 1. i checked clutch, clutch shop said its fairly new 2. tranny was taken to shop, mechanic said it needed 3rd gear work plus synchro. that was done 3. all is back together, but the same problem exists. cant change gears while running, clutch adjustment done too. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I wonder if you have a steel pilot bushing and the clutch gear (input shaft) is seized to the bushing making the crank and transmission turn as one.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | 1. i checked clutch, clutch shop said its fairly new That sounds like the common statement "The battery is only a year old. It should be able to start the engine". I would suspect the clutch hanging up as well like sstock said.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | well i got the canopy back from the "mechanic" the shift box was what i thought the problem was, i took the lid off and it had no grease. i put grease in it and was goign to adjust arms, but before i do that how can i adjust them. i know in neutral but make the rods the same height? video
