9 members (Peggy M, Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, 1 invisible),
69
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | Today I finally got the corner windows installed, but now I have a minor problem. Because I had plastic taped over the opening for so long I have some serious residue from the masking tape. I tried taking it off with some soap and water, which didn't do anything. Then I tried mineral spirits, but again no luck. I really need to get rid of this stuff, but I'm afraid of damaging the paint.
Does anyone have a good suggestion?
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | WD-40. Spray it on generously, let it soak, tape residue will come right off. Doesn't hurt paint.
1951 Chevy Panel Truck
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Miraclepieco has the answer, has worked for me many times.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | lighter fluid (naphtha) works. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | You can get real aggressive with stuff like lacquer thinner, acetone or starting fluid but you'd be risking paint damage. The WD is slower but doesn't hurt anything.
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Maybe using some Goo Gone will work quicker? | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | WD40 is what I always use on all surfaces. Works great and like previously said wont hurt the paint. Not to mention its cheap.. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Warm soapy water , rubbing alcohol, WD40 , wax and grease remover , heat from a hair dryer. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If an employee in my shop is caught with WD40 I'd fire him and if a non-employee is caught I'd have to kill him. With high dollar paint jobs on the line one just can't have WD40, Armorall, or anything with silicone. One second of spray will cause one year of fish eyes. We use 3M adhesive remover.
Evan
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Standard/original formula WD-40 contains no silicone.
WD-40 does sell a silicone lubricant. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | If an employee in my shop is caught with WD40 I'd fire him and if a non-employee is caught I'd have to kill him. With high dollar paint jobs on the line one just can't have WD40, Armorall, or anything with silicone. One second of spray will cause one year of fish eyes. We use 3M adhesive remover. Funny the things that trigger an old memory...A friend had an old convertible we decided to paint stripes on. Years of armor All on the top rad down on the paint and tape just fell off.We tried everything! He finally asked his wife for suggestions. She asked "did you try formula 409"? You could see him cringe that I heard her suggestion...Guess what finally made the masking tape stick. | | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | Update on removing tape residue. I guess that tape had been on there so long (like a year in places) that it was permanent. After trying all suggestions I finally ended up using a razor blade to scrape it off, which tokk very little time. Then I went back a did some touch up painting, and now things look pretty good.
Tim
