0 members (), 186 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
Well I finished installing my rotten pine bed wood with plastic deck boards. It looks very nice. Nice naturalish color and wood grain. I got lucky with the dimensions of the old bed wood and the new deck boards. The old eight board bed wood measure 5 3/4", but the plastic boards measure 5 1/2". I was able to cheat by moving the outer boards inward, thus preventing gaps which would not be covered up by the bed strips.
I cut spacers out of the scraps of the plastic boards to keep the wood from moving side to side (plastic doesn't expand like wood, so these spacers won't cause any buckling). I drilled holes in the middle of the spacers so that bed strip bolts will keep them in place. I put the spacers between the boards on the top of the 3 center cross sills (21 in total). I did have to drill a few holes in some of the cross sills to accommodate a few of the bed strip bolts, but not as many as I thought that would.
By the way, I did not router the grooves on the edges of the plastic boards for the bed strips. You can't even tell the difference. The grooves in the wood boards are there to capture the bed strips to keep everything in place when the wood expands and contracts. Not needed with plastic boards.
Carl
Former BMW Rider
Former BMW Rider
Pictures my friend, we need some pictures!
..........or not.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Pics before bolts installed.
Carl,
That looks Great !!
1950 Chevy 3100
Unconventional Thinker
Looks good, and will last a long time.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Thanks, Carl
If/when my soon-to-be-painted bed boards go bad, I'll be looking for black plastic deck boards.
I bought the boards several years ago - when "plastic" decks boards were uncommon and untested.
Nice job.
Fox Offline
Me likey a lot. Very slick.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Looks nice. Couldn't help but notice your brush ax. Working truck or window dressing? My first real job out of high school was on a track gang for the railroad. I learned to hate those brush axes. I cringe every time I see one.
Dave from Northern Kentucky
My 54 3100
Former BMW Rider
Former BMW Rider
Thanks for the pics Carl. I'm with these guys, it really looks great!
Nice work!! thumbs_up
Andy
Thanks for the comments! I was contemplating painting it black, but I don't know how well it would hold up on the plastic. Besides that, the pattern which they put into it makes it look like wood. This truck is my daily driven work truck, so I don't want it to look too nice.
Dave, the Kaiser blade (some people call it a sling blade, I call it a Kaiser blade, emm hmm) is what I consider to be crowd control.
$294.24 plus tax for 8 boards, but you won't ever need to do it again.
The boards that I used were about half that price, but if I had seen those 1X6 boards that color when I bought mine, I may have been tempted to splurge for them.
What a great looking bed!
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
I'm thinking a "Tech Tip" here. Carl I think you got a winner with this.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
interesting concept. and it looks great. I wonder how well they would hold up on a working truck tho? Especially on a hot summer day, I know my plastic deck boards get a little softer at the end of a hot day in the sun.
Another quality post.
Real Trucks Rattle
What brand of board, Rusty Rod?
How old are the boards?
What is the brand?
I had some deck boards installed two years ago. They do not seem to get softer in NC coastal sun.
They might get harder in a cold winter, but I will never know,
TC, not sure, but they are almost an inch thick
Real Trucks Rattle
Big Bolt Forum Moderator
when I put my deck on my house a number of years ago, I needed to add more support for the plastic boards than if they were wood. it will get warm and warp, and also expand BUT, it is sure nice not to have to paint it or worry about rot! I would think they should hold up well in a pickup bed. Mine were "evergrain" brand.
Mike
How far apart are/were your floor joists, Mike?
My truck is parked in the full sun all day. Time will tell how it holds up. I figure if it works on a deck, it will work on a truck bed. These boards are ribbed on the bottom. Hopefully that will provide some rigidity.
we went 16" on center instead of 24"
Mike
JD1 Offline
Carl,
That looks good.
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
I am away from home, but, I'll try to remember to check joist-spacing on my house-deck boards - NC near-shore sunshine, reaching over 100 degrees with no buckling/sagging.
24601
Interesting idea, Carl. But with the nominal lengths available being 8 or 16 ft, it would seem only the 3/4-ton guys wouldn't end up with left overs. Maybe I'd have to find a 1/2-ton guy to go in with on those 16 footers ...
(not that I'm contemplating replacing Charlie's nearly pristine original bed wood ... just struck me that it is a lot of $$ possibly spent on product you can't use -- especially the 1-ton guys)
JM
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Any concern about tail pipe close to it or is the original heat shield sufficient?
•1952 Chevrolet 3800 pickup
---All pictures---
16" on center
Therefore, I do not now if they would sag with a wider spacing.
Without a load, the tailpipe isn't all that close on mine.
