0 members (),
40
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Picked up a nice triangular shaped wire mesh Weiand air filter at a swap meet. The foam filter needs replacing. The hole in the bottom fits my single barrel Rochester perfectly. After I replace the foam filter are there any pros or cons on using this on my old truck? Just wanted to replace the oil bath cleaner for now. | | | | | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | Pray to god there's never a carburetor backfire cause it will melt the foam, and then it will get sucked down into the engine. They do look kinda cool though. Later
Dave
Even a blind squirrel gets a nut sometimes!
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | got a screen on the inside???? of the air cleaner.? if so no troble.The down draft will suck the flame out.parts store sell fire retardent filters
dan-pa
| | | | | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | There's usually a couple of pieces of wire that hold the foam...when the foan gets blasted with a backfire it will melt. Been there done that got the t-shirt. Later
Dave
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | mine fell off and got ran over... just make sure the wire clips are properly secured...
