2 members (Wally / Montana, Gdads51), 84 guests, and 5 robots.
Topics128,065
Posts1,055,868
Members48,428
#132559 06/13/2005 2:42 AM
Picked up a nice triangular shaped wire mesh Weiand air filter at a swap meet. The foam filter needs replacing. The hole in the bottom fits my single barrel Rochester perfectly. After I replace the foam filter are there any pros or cons on using this on my old truck? Just wanted to replace the oil bath cleaner for now.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#132560 06/13/2005 3:06 AM
Pray to god there's never a carburetor backfire cause it will melt the foam, and then it will get sucked down into the engine. They do look kinda cool though. Later
Dave
Even a blind squirrel gets a nut sometimes!
#132561 06/14/2005 7:53 PM
got a screen on the inside???? of the air cleaner.? if so no troble.The down draft will suck the flame out.parts store sell fire retardent filters
dan-pa
#132562 06/14/2005 8:17 PM
There's usually a couple of pieces of wire that hold the foam...when the foan gets blasted with a backfire it will melt. Been there done that got the t-shirt. Later
Dave
#132563 06/15/2005 2:51 PM
mine fell off and got ran over... just make sure the wire clips are properly secured...
Another quality post.
Real Trucks Rattle
