7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2019 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 13 | Does anyone have a source for the rear leaf springs on a 3/4t 53’ Chevy? I am in need of both the mains and the helpers Thanks guys! | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | SD Truck Springs carries then too. I also believe The Suspension King too. | | | | | Joined: Mar 2016 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 17 | Do you need new or will used originals work? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Please read the site rules on buying/selling outside the Swap Meet Forums. Thank you.
| | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | You may have luck talking with your local truck repair shop, particularly if you can give them a sample to work from. I have a local shop that does quite a bit of spring and suspension work and their spring shop can source or fabricate almost any spring from a lightweight utility trailer to truly HD truck springs - old to new. The last job I gave them was overhaul of springs for a WW2 Canadian army trailer (re-bush, replace broken leaves, new clips and center bolts, re-arch), satisfactory result. | | |
