2 members (homer52, Tronman), 113 guests, and 5 robots.
Topics128,077
Posts1,056,033
Members48,433
#1324285 08/31/2019 12:59 PM
Does anyone have a source for the rear leaf springs on a 3/4t 53’ Chevy? I am in need of both the mains and the helpers
Thanks guys!
' Offline
Try this company .
They make springs from oem blueprints .
https://www.eatondetroitspring.com/leaf-springs/
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
SD Truck Springs carries then too. I also believe The Suspension King too.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
ADH Offline
Do you need new or will used originals work?
Please read the site rules on buying/selling outside the Swap Meet Forums. Thank you.
You may have luck talking with your local truck repair shop, particularly if you can give them a sample to work from. I have a local shop that does quite a bit of spring and suspension work and their spring shop can source or fabricate almost any spring from a lightweight utility trailer to truly HD truck springs - old to new. The last job I gave them was overhaul of springs for a WW2 Canadian army trailer (re-bush, replace broken leaves, new clips and center bolts, re-arch), satisfactory result.
