1 members (KEVINSKI), 119 guests, and 2 robots.
Topics128,162
Posts1,056,943
Members48,458
Brief history: Original 4cyl had been replaced with a 6cyl 216 which had huge freeze crack in block. Pulled 216, patched hole in firewall, installed Mercruiser 153 4 cylinder and lengthened everything that had been shortened due to 216's longer length. Milled the water flow exhaust off the siamesed intake and installed an early 60's 153ci ChevyII exhaust manifold. Fired engine and it is so smooth running it has a drone to it. Have no idea what cam a Mercruiser has but it does have a heavy iron flywheel now. The distributor is still the no vacuum advance tightly sealed boat unit which may have to be replaced with one with the vacuum advance. Can't test drive till figure out why it moves 6-8 feet and locks up the right rear wheel. Axles are out so it can't be anything in the differential. A test drive will show whether the boat distributor will work. Original post with pictures 12-04-2018.
Evan
Does the right rear wheel rotate freely when on Jack stands transmission in neutral?
It is a 2T truck so with the axle out it only turns the bearings on the spindle---no connection to differential or driveshaft. It has mechanical brakes so moving the lever should move shoes completely away from drum but drum may be warped or out of round. Will switch other side drum/hub to right side and see what happens. Thanks for any ideas.
Evan
Originally Posted by coilover
It is a 2T truck
Evan, are you sure it's a 2-ton truck? I always thought the 2-ton trucks were introduced in 1946.
Which model is your truck? Model LO (early 1928) has 2-wheel brakes and Model LP (late 1928) has 4-wheel brakes...both are 1-ton rated.
I couldn't find your pictures...can you add a link?
If the truck only rolls 6' with both axles out you may just be piling up a bunch of loose rust/dirt between the drum and shoes...I'd keep rocking it back and forth and see if it starts moving further each time.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike, the whole world now knows you are a heck of a lot smarter than me on early Chevy trucks. It has 4 wheel brakes and we pulled all drums and hubs and cleaned to bare grey metal. Cleaned, checked for pits, spun, and re-packed wheel bearings. Brake shoes were new so may have to re-arch for drum fit. When it locks up the wheels on my tow truck spin but it doesn't budge. With something this radical one should be able to isolate the problem.
Evan
Evan, try gluing a piece of sandpaper for an air file inside a brake drum, and scuff the brake shoes back and forth against it to match the radius. Since anybody who uses a brake lining grinder these days is likely to get 30 days in the electric chair, that's a pretty good work-around!
Jerry, that's a heck of an idea and one I've never done but soon will try.
Mike, I couldn't find any up to date pics but here are a few beginning ones:
[img]https://i.postimg.cc/xJJv8yQ2/IMG-4658.jpg[/img]
[img]https://i.postimg.cc/rDHzs6wD/IMG-4656.jpg[/img]
[img]https://i.postimg.cc/xqPG6PR6/IMG-4659.jpg[/img]
Evan
Your truck is not a 1928. 1928 Chevy trucks had wood spoke wheels and no duals on the rear. The radiator shell is from a '29 or '30 car. Trucks had painted shells. It must be a '29-'32, which would have had a 194 c.i.d. inline 6 cylinder engine when new. If you have the hood side panels, they would help to visually identify your truck. If it has a factory I.D. tag, it will tell what you have. Chevrolet did not use a full floating rear axle on 1-1/2 ton trucks until 1936, so the rear end is 1936 or later. Only the early 1936 trucks had mechanical brakes. The change to hydraulic brakes came fairly early in the model year.
You can go to Google image and enter 1929 Chevy truck, then 1930 Chevy truck, etc until you find pics that match your rig. Good Luck.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
Mike,
Wish you could pack up your tools and jump in to help on this project. Another has told me the cab is a Dodge so from now on I better call it a Franken Truck. The history on it is it was bought and taken to a gold mining operation and never registered for highway use. I definitely had a 4 cylinder because there is no room for an inline six engine. When we got it there was a 216 Chevy that stuck through a hole in the firewall back into the cab. The driver was tough because the foot feed was up against the side of the exhaust manifold. The dump lever rods, pto shaft, and torquetube/driveshaft had all been shortened to accommodate the six cylinder. Has a 153ci four cylinder (Chevy II, Mercury Marine) engine in it now that fits both the firewall and the fan to radiator very well.
Evan
