0 members (), 132 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
0
0 Offline
Looking for a 1970 C30 transmission X member in the parts wanted section....Had a comeback for a C20....Does anyone know if the 20 & 30 share the same transmission X member?
This might not be relevant to you, but I successfully swapped an '85 c30 crossmember on to my '63 c10 frame, and I only had two holes that didn't line up. Squarebody (73-91) c30 crossmembers should work for you unless you are trying to stay original.
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
0
0 Offline
Originality is not an issue..My truck is an in process restoration with intention of using it when I have a chore for a 1 ton mason's dump truck.....This transmission X member is factory riveted in, so it will require some effort for someone to remove it from a doner vehicle..probably why nobody is chomping at the bit to sell me one... The frame & undercarriage of this truck has no rust, however the X member has rust holes that I can't explain, other than dirt getting packed in there acting as a sponge for 50 years...c20 & c30 share a lot of mechanical/suspension parts I just wanted a confirmed answer if the transmission X members are the same.....Thanks for your comeback...will keep it in mind.....
Wow, I completely misread your post. I thought you were looking for the front suspension crossmember for some reason. My bad.
I would think it would be the same as a C20 and I think the 6 cylinder manual trans C10s also had a similar one.
0
0 Offline
Have a 'wanted' ad, in 'truck parts wanted' Thanks
