| | | Forums66 Topics128,179 Posts1,057,133 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 46 | I have a 454 I'm dropping in my '50 3600. I have mii front end with power steering. Has anyone successful done this swap with stock wngine mounts? I still have the rv I pulled the motor and tranny out of. So, I figured that if I have to modify the universal mounts I may be able to use the stock ones.
Anyone with pictures would be very helpful. Tried to search the site but a million things come up not related to my search. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Chassis Engineering (now owned by Heidt's) has mounts for just about any swap and used to offer them in either bolt in or weld in. By far the easiest is the ones that use a bracket that bolts to the engine and the frame bracket either bolts or welds to the frame. These take the Flathead Ford mount biscuits and are super stable plus you will love being able to set the engine straight down onto the cushions rather than fight angled mounts. With the torque of a big block one might use the tube that runs from frame rail to frame rail and has the brackets to take the factory mount cushions. We don't use this set up often because the tube is in the way of everything. If you do a search on "Chassis Engineering Motor Mounts" many are listed but I would call them and tell what you are doing.
Evan
| | | | | Joined: Jan 2019 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 46 | They definately have what I need but jeeze, $170 for some moints seems a little steep | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | What’s your time worth? $30/hr? $60? 100$ They pay for themselves pretty quick. Do you have fabricating skill? Tools? Material? | | | | | Joined: Jan 2019 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 46 | I think I found what I need from speedway. Transdapt makes something i think I can modify to work | | |
