2 members (Wayne67vert, 66flea), 297 guests, and 4 robots.
Topics128,156
Posts1,057,018
Members48,460
I have a 454 I'm dropping in my '50 3600. I have mii front end with power steering. Has anyone successful done this swap with stock wngine mounts? I still have the rv I pulled the motor and tranny out of. So, I figured that if I have to modify the universal mounts I may be able to use the stock ones.
Anyone with pictures would be very helpful. Tried to search the site but a million things come up not related to my search.
Chassis Engineering (now owned by Heidt's) has mounts for just about any swap and used to offer them in either bolt in or weld in. By far the easiest is the ones that use a bracket that bolts to the engine and the frame bracket either bolts or welds to the frame. These take the Flathead Ford mount biscuits and are super stable plus you will love being able to set the engine straight down onto the cushions rather than fight angled mounts. With the torque of a big block one might use the tube that runs from frame rail to frame rail and has the brackets to take the factory mount cushions. We don't use this set up often because the tube is in the way of everything. If you do a search on "Chassis Engineering Motor Mounts" many are listed but I would call them and tell what you are doing.
Evan
They definately have what I need but jeeze, $170 for some moints seems a little steep
Fox Offline
What’s your time worth? $30/hr? $60? 100$ They pay for themselves pretty quick. Do you have fabricating skill? Tools? Material?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
As Fox says: what is your tool situation? Here are home made mounts to fit a sbc into an MGB. Cut from scrap 3/8 plate, drilled for block mount holes, heated and bent to fit down on the Flathead Ford mount biscuits ($20) and a 3/8 strap welded to the MG frame. Can't get you out any cheaper than this.
[img]https://i.postimg.cc/PNPHZF3m/V8-MGB-009.jpg[/img]
[img]https://i.postimg.cc/MnwgssD3/V8-MGB-008.jpg[/img]
Evan
I think I found what I need from speedway. Transdapt makes something i think I can modify to work
