2 members (Thomaslb, Eddie54), 166 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
Just wondering how to convert my stock 2 socket # 63 lamps 6 volt stop and turn light into an led. I was thinking of swapping in an 1157 socket and then buying the 6 volt 1157 led. Will this work? The truck is a 46 1/2 ton thx Kevin
I tried that and had an issue with how the replacement LED bulbs need to aim straight back to be seen, and the that the sockets in stock tail lights are on an angle. They were more dim than the original bulbs.
The #63 bulb supposedly had a BA15s base.
This 6v bulb supposedly fits that base?
Thanks for the responses
Do the sockets inside of your tail lights point straight back?
They are listed on Amazon.Here. You will have to get a heavier duty flasher or the turn signal will not work.
Must use load Resistor item 34205 (need 2) or item 34235 when used with 6 volt LED lights. Go to LMC online catalog they have conversion led lights that fit in stock mounts.Lights
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Yes my socket is angled. I was thinking maybe the regular flasher may work because I am leaving the incandescent bulbs in the front they seem fairly bright with the frosted glass. Probably be a bit of trial and error to get it figured out. I just ordered some led bulbs that tclederman suggested, it will be about a week before I get them. Thanks for the information
I probably do not have to ask, but: please let us know hows this works-out for you.
Does anyone know what load resistors I should use. There doesn't seem to be a lot of info on them. None seem to be 6 volt, or can you use the 12 volt ones. Also what ohms and watts should they be. The leds I am using are 1156 w19 6v Thx
WE b OLD gave you the answer.........
“They are listed on Amazon.Here. You will have to get a heavier duty flasher or the turn signal will not work.
Must use load Resistor item 34205 (need 2) or item 34235 when used with 6 volt LED lights. Go to LMC online catalog they have conversion led lights that fit in stock mounts.”
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Ok, what two tabs should the resistor cross in order to work correctly?
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
If you are installing LED lights you will need to replace your turn signal flasher as well. LED lights don't have the resistance needed for a stock turn signal flasher.
