0 members (),
123
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Just wondering how to convert my stock 2 socket # 63 lamps 6 volt stop and turn light into an led. I was thinking of swapping in an 1157 socket and then buying the 6 volt 1157 led. Will this work? The truck is a 46 1/2 ton thx Kevin | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I tried that and had an issue with how the replacement LED bulbs need to aim straight back to be seen, and the that the sockets in stock tail lights are on an angle. They were more dim than the original bulbs.
| | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Do the sockets inside of your tail lights point straight back?
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | They are listed on Amazon. Here. You will have to get a heavier duty flasher or the turn signal will not work. Must use load Resistor item 34205 (need 2) or item 34235 when used with 6 volt LED lights. Go to LMC online catalog they have conversion led lights that fit in stock mounts. Lights
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Yes my socket is angled. I was thinking maybe the regular flasher may work because I am leaving the incandescent bulbs in the front they seem fairly bright with the frosted glass. Probably be a bit of trial and error to get it figured out. I just ordered some led bulbs that tclederman suggested, it will be about a week before I get them. Thanks for the information | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I probably do not have to ask, but: please let us know hows this works-out for you. | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Does anyone know what load resistors I should use. There doesn't seem to be a lot of info on them. None seem to be 6 volt, or can you use the 12 volt ones. Also what ohms and watts should they be. The leds I am using are 1156 w19 6v Thx
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | WE b OLD gave you the answer.........
“They are listed on Amazon.Here. You will have to get a heavier duty flasher or the turn signal will not work. Must use load Resistor item 34205 (need 2) or item 34235 when used with 6 volt LED lights. Go to LMC online catalog they have conversion led lights that fit in stock mounts.”
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | Ok, what two tabs should the resistor cross in order to work correctly? | | | | | Joined: Dec 2019 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2019 Posts: 36 | If you are installing LED lights you will need to replace your turn signal flasher as well. LED lights don't have the resistance needed for a stock turn signal flasher. | | |
