7 members (Otto Skorzeny, UtahYork, arustycars639, Ponchogl, 5cameo8, Gray_Ghost, jmoore), 88 guests, and 0 robots.
Topics128,108
Posts1,056,562
Members48,448
Getting ready to install my headlights and am wondering if I need the 3 screw blocks for wiring. Don't see any holes in my inner fender walls so where did they mount ? Thanks for any help. Bill
1937 GC
back yard wrench turner
They mount on the radiator/grill cowl. The same as my '38.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Could you send me a picture? Text pictures ok..906-284-9448 thanks Bill
1937 GC
The '37 did not have terminal blocks. The 3 wires to the headlight (high beam, low beam and parking light) terminate in a metal connector that plugs into the headlight bucket. I was missing these pieces when I purchased my truck. On the advice of someone familiar with a similar system in Model A Fords, I eliminated the metal connector and hard wired the headlights, leaving a foot long loop of each wire coiled in the bucket, in case the bucket needed to be removed and the wires cut, in the future. The connector is a source of trouble due to corrosion and poor contact leading to dim or non functional lights.
I have seen the connectors twice on Ebay in the past 4 years, so they are uncommon and no one makes a reproduction that I am aware of.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Thank you for the reply Kent. No sure what I am going to do yet. Bill
1937 GC
Sorry Bill, I misunderstood what you were asking. I thought headlight stands.
When I converted my headlights to HID's, I put inline connectors into the headlight bucket so I wouldn't have to cut wires at a later date.
Wayne
1989 Silverado
When I wired up my 39 with an aftermarket "stock"ish harness, I added a relay to the headlights, but there was no terminal block.
Another quality post.
Real Trucks Rattle
