| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 20 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 20 | I bought a 61 235 Chevy engine to install in my 41 Super Deluxe and need to change the front engine mounting plate in order for the original mounts to work on the newer engine. Does anybody have one laying around that they'd like to sell? I would also like to get the two rocker shaft mounting studs that hold the valve cover down since I want to make the 235 look as close to the 216 as possible. Or, does anybody know of a place to purchase these other than RPM Motor Sports? They are sold out at present. Seems as though quite a few folks have the same idea that I do. That's scary!! Thanks, fellas!
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Most people just drill the timing plate to fit the mounts. I think there's a tech tip somewhere with a template diagram to follow. The valve cover studs aren't engine-specific. A specialty bolt place like Fastenal or ARP should be able to provide 3/8" diameter studs the right length with a 16 TPI thread on one end and 24 threads per inch on the top. 3/8-24 acorn nuts and 3/8 SAE flat washers are available on Ebay to complete the installation. Jerry.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 |
Mike
| | | | | Joined: Oct 2016 Posts: 11 New Guy | | New Guy Joined: Oct 2016 Posts: 11 | Can't you just pull your studs and valve cover off the existing 216 and use those? I did that to a '60 235 with 4 cover screws; pulled the studs and cover off the '52 235 and used them on the new head. I would think it would be the same size stud? | | |
