3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#1323302 08/24/2019 6:42 PM
I know they're not electrical but I am trying to use my original vac wiper system. I order the "improved" wiper arms from classic parts. Everything works fine until I put the arms and wipers on. Nothing moves. It seems like the springs in the new arms are holding it too tight against the glass....or my motor is not strong enough. Any body else experience this?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Take your motor apart and clean it up then lube the seals with a vaseline
H Online: Content
Most vacuum wiper motors have a tubing nipple that is open to the atmosphere where air is drawn into the housing by manifold vacuum. Attach a piece of tubing to that port and submerge it into a bottle of gas treatment or fuel injector cleaner. As the liquid gets pulled through the motor it cleans and lubricates the flapper that operates the wiper arms. It's simpler and easier than dismantling the vacuum motor, and then the solvent cleans the valve guides as it gets pulled through the manifold and cylinder head.
AD Addict & Tinkerer
I recently went thru the same dilemma. Using a vacuum cleaner to operate the wiper motor it only operated in one direction. I soaked the internals of the motor overnight in brake fluid. I got it to operate in both directions but it was easy to stop by hand. The gasket that seals the cover to the body are paper thin. I figured the chances of getting the motor open without ripping the sixty seven year old gasket were slim and rebuild kits are not available. I ended up sending it out to Ficken Wiper Repair https://rebuildingtricowipers.com, aka “Wiperman”, and and it’s real strong. I payed $135 shipped with a 1 week turnaround. A dry windshield won’t stop it!
Highly Recommended!
Phil
Project Journals
Stovebolt Gallery Forum
Yeah, I've tried the fixes mentioned above. Looks like I'll have to contact the wiperman. Thank you for posting the price. I was curious about that.
Send him a email posted on his website. He’s pretty quick to respond.
Phil
Project Journals
Do these "improved" wiper arms address the too strong springs issue?
Did you test your wipers with a wet windshield?
I originally thought the spring was too tight so I sprung the spring to relieve some pressure. Still didn't work. Then sprayed my windshield with windex and one side would run. When I put both arms on, it was too much even with a wet windshield.
I found the newer arms created too much friction for my vacuum motor. I switched back to the old arms. They would work fine with the electric wiper setup.
1951 1 Ton Completed
