3 members (moparguy, stlcardinalsguy, Cosmo), 141 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
Chief Bottle Washer
Chief Bottle Washer
Hello all,
Please refer to the enclosed pics. On my '52, 3100, 216 cu in, it appears there is an additional set of heater hose connections. What do these unused connections belong to?
Thanks for any ideas, and editor, please feel free to move this to a more appropriate forum.
Best to all,
Jim
Riding in the Passing Lane
Those are for the heater control valve that come with deluxe heaters. They are very prone to leaking, more like gushing. They are often bypassed like yours has been. If you want to hook it up you need to replace or rebuild it.
George
1972 Chevy c10 Cheyenne Super
It is called a ranco valve if you want to look it up ,there is posts on how to rebuild or info on who can rebuild if you are interested
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
You can rebuild it to stop it from leaking, or you can disassemble it and re-engineer it to delete the seal so that is will never leak again. It won't operate any longer, but they never really did work very well anyway. You want the coolant to just flow right through with some restriction. If you don't provide some restriction in it, you will melt the shoes off the ole lady.
2 Offline
yes that looks original
here is a diagram i found online
I've seen that picture before. It always bothered me that they crossed the hoses at the valve. I put mine on without crossing the hoses before I saw it, but now I don't want to make a mess by switching them around so that they are on the "right" way. I will do it before next Homecoming just in case Tim 'tclederman" shows up. smile
Carl
It will work either way, but, you will always know which way it should be.
