8 members (Phak1, 68ironhead, Bill Hanlon, Peggy M, 3B, Oswald, elhippie64, 1 invisible),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 25 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 25 | The gasket that was on the nut for the opening ripped off last night when I opened it to check the levels (empty!). It was the first time the master had been opened in a decade so it basically ripped apart. I am having issues finding a replacement gasket as everything seems to be susceptible to Dot 3 fluid. Is it required or can it be metal on metal? I'm thinking something should be there to prevent extra air getting into the system. If its required what have you used if you were not able to source the actual part from anywhere?
1958 Chev Apache 3600
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I think you can still buy gasket material at the parts stores. Careful work with a razor blade and your good to go.ðŸ›
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | I've made very effective master cylinder gaskets from soft aluminum sheet metal or copper. All it takes is some careful drilling and filing for the inside diameter, and a good set of tin snips for the OD. They last WAY longer than paper gaskets and also seal better. Most master cylinder plugs have a small vent hole drilled into them from the side. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The fill hole plug gasket is for splash out. Air getting in can't get thru the fluid. Otherwise every time you checked it, air would get in system. It probably does not even need a gasket.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2018 Posts: 25 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 25 | Thanks guys, I'll keep an eye on it and look into the gasket material or copper. Its a reason to get a new tool as I don't have snips!
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Do you want me to delete my post showing an original replacement gasket for $2?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2018 Posts: 25 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 25 | Whoops, didn't see the link, thanks! I'll see if I can find that in Canada or else a $2 part will be $4 + $20 shipping :-)
