5 members (Gray_Ghost, UtahYork, Gdads51, Lostbuthaulinass, amtrakjoe), 63 guests, and 3 robots.
Topics128,079
Posts1,056,303
Members48,441
I am referring to the 4138 AC unit for 261 truck motor. Does anyone know which vacuum port is intake and which is exhaust or does it matter? This is the fuel pump with the vacuum pump on the bottom of the fuel pump. When I move the pump lever I cannot tell which one is which. There is one port closer to the motor and one further away.
I know one is supposed to go to manifold and one to wipers. Thanks in advance.
1953 Chevrolet Handyman Wagon 36k
1938 Buick 38k
1947 Hudson Commodore 18k
I have a dual action fuel pump and A/C on my 54 and there is a hose coming off the bottom to the A/C but is to the right side of the pump as far as I can tell reaching under the pump.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
It's simple- - - -remove both hoses and attach a vacuum gauge to the pump nipples with the engine running. The one that pulls a vacuum goes to the wipers. Connect the hose from the intake manifold to the other one. You've got a 50/50 chance of being correct by simply attaching the hoses at random, but it's easy to do it right.
It's on the stand right now.
1938 Buick 38k
Loosen the pump bolts a couple of turns and wobble the housing up and down- - - -that's plenty of movement to get a vacuum reading. It's too bad common sense isn't an off-the-shelf item at a parts store.
If you are implying I have no common sense that's not the case buddy. Hey thanks for the help.
1938 Buick 38k
Moderator
Moderator
2 Offline
BigBlack
Jerry is a little rough around the edges, but a wealth of knowledge in that old noggin of his.
If you ever meet him in person, you will understand.
Please don't take any offence.
Hope you try his idea and it works out for you.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
No offense intended- - - -after 60-something years in the auto repair business and teaching the subject for 30+ of those years, some things that appear to be an obvious solution to me don't occur to others.
I consider myself fairly knowledgeable with these old trucks and most things come easy to me.
Add a frustrating series of issues without any success in resolution, then the cuss words and tools start flying, and I find myself in need of someone like HRL to reel me back in.
Insults, manhood questioning, etc coming from him doesn't bother me. His background is High school automotive education. I think back 40 something years ago about my old shop teachers, and HRL seems like a cream puff in comparison. I met him in person a few times. He is indeed a cream puff, and his #1 goal is to selflessly help anybody who needs it.
Carl
Y’all are gonna make him blush! blush
Moderator
Moderator
2 Offline
Jerry blush? Never!
Maybe a smile and a chuckle though!
Don
"The Flag Pole"
1953 1-ton pickup
The reason we could not determine which port was which, was the lower pump diaphragm was torn and not working. We ordered a new pump and down the road we go. Thanks.
1938 Buick 38k
