| | | Forums66 Topics128,120 Posts1,056,649 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I’m starting to assemble my ‘57 1/2 ton NAPCO project and I can’t remember what was originally going on with the rear axle. I have a bearing, a seal, and what looks like a shim. When I look at the factory service manual, I don’t see the shim. Does anyone know where that shim goes and why it’s there?
Thank you LJ
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy LAJones48, could you provide us with pictures of the components you are inquiring about? | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | [img] https://www.stovebolt.com/ubbthread...B103831-7171-404C-B487-87A7593C6CC7.jpeg[/img] Here’s what I have. I think I understand how to assemble it now after rereading the manual. The part I’m really unsure about is the gasket between the oil slinger on the axle flange and the flange itself. Do I need to take that apart and replace the gasket if I don’t see any oil on the inside surface of the flange? Thanks, Larry | | |
