0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1321958 08/15/2019 2:10 PM
AD Addict & Tinkerer
I’m trying to straighten out my wandering 52’ 1/2 ton and run into the leaf spring eyes being worn to the the point where they need replacement. Can I buy just the one spring with the worn eye (both sides) or should I just replace both of front springs?
Phil
Project Journals
Stovebolt Gallery Forum
2 Offline
a good spring shop will make you any new part for a leaf spring
bring them the old part, they have stock spring material in all thicknesses and widths to make any shape your heart desires.
special tooling allows then to heat and form a spring eye to any diameter
they can make you a whole new spring assembly or they can rebuild the existing spring assembly and replace only worn leaves and rivet/crimp it all back together for you
the sky is the limit
-s
Van
Van
After I replaced the front springs on my 59 Apache I highly recommend doing that! The ride has improved greatly, and it holds the road way better. Less chasing with the wheel.
1959 Apache swb stepside
Atlanta Ga.
I need to clarify my post. I meant to say, disassemble the spring stack and replace the main spring with the eyes, then reassemble and re-clamp them together. Or, should I replace the whole spring. Whatever I do I will do it on both sides.
Phil
Project Journals
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I would keep the rest of the stack of springs and just buy the single main springs.
I have one AD with really good springs and another with sagging springs.
Guess which one rides much gentler?
V
V Offline
Uhh, I'll pick C, LOL.
I 2nd replacing the main spring and reusing the rest. Nothing wrong with all new tho, all depends on how deep you want to go into your pockets, LOL.
