| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I’m trying to straighten out my wandering 52’ 1/2 ton and run into the leaf spring eyes being worn to the the point where they need replacement. Can I buy just the one spring with the worn eye (both sides) or should I just replace both of front springs?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | a good spring shop will make you any new part for a leaf spring bring them the old part, they have stock spring material in all thicknesses and widths to make any shape your heart desires. special tooling allows then to heat and form a spring eye to any diameter
they can make you a whole new spring assembly or they can rebuild the existing spring assembly and replace only worn leaves and rivet/crimp it all back together for you the sky is the limit -s
| | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | After I replaced the front springs on my 59 Apache I highly recommend doing that! The ride has improved greatly, and it holds the road way better. Less chasing with the wheel.
1959 Apache swb stepside Atlanta Ga.
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I need to clarify my post. I meant to say, disassemble the spring stack and replace the main spring with the eyes, then reassemble and re-clamp them together. Or, should I replace the whole spring. Whatever I do I will do it on both sides.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I would keep the rest of the stack of springs and just buy the single main springs. I have one AD with really good springs and another with sagging springs. Guess which one rides much gentler?
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Uhh, I'll pick C, LOL.
I 2nd replacing the main spring and reusing the rest. Nothing wrong with all new tho, all depends on how deep you want to go into your pockets, LOL.
