8 members (Phak1, 68ironhead, Bill Hanlon, Peggy M, 3B, Oswald, elhippie64, 1 invisible),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Anybody got any idea's on how to find a rebuild kit for my 51 GMC 3 ton 270 ? I had it professionally cleaned and it still is bogging down real bad and stalls out. I may need a new carb, but thought a rebuild might be worth a try.
Thanks, Troy | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I bought a 55 first 1/2 ton with a 261 in it. Rebuilt the carburetor and it ran terrible. I learned the hard way. It had a badly rusted (inside) fuel tank which means I had rust in the fuel lines, fuel pump, fuel filter and my newly rebuilt carburetor. Replaced all of it and rebuilt the carburetor. Filled it with Non-Ethanol gas. Much better now but not ideal. Next step is to replace the Rochester B with a Zenith. For a Zenith, I would go to The Carburetor Shop website and see what model Zenith is listed for your truck. There is a round brass tag on the top of your carburetor that has a stamped ID number. For the ID number there is a matching kit number listed on the website as well as a phone number to call. Carbking is much better on this than I am but you may need a few special tools.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Thanks guys, I will check for the id number and look at their website and try and figure it out. Then, maybe I can get a kit ordered. I really appreciate ya'll getting back to me on this.
Troy | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I'm watching this, I just bought a Zenith 228 yesterday for my 261, and the carb does need a rebuild.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Zeiniths are not hard to overhaul but you do need to take your time and make sure everything is squeeeky clean. Also accuracy in measurement counts. Fuel pressure is also important. Also bear in mind that alcohol in the gas will make things run leaner and if you're working the truck hard can have bad results. I have had valve stems stick and temporarily stuck a piston when I picked up a tank of gas with too much alcohol. One eights turn on the main jet fixed that. These zenith carbs were available with adjustable main jets. I have two. I don't know if they are available now but it's worth asking.
One thing often overlooked is throttle shafts. When these wear they leak air and the idle speed won't be consistent -- sometimes high, sometimes low sometimes rough sometimes smooth. You need a drill press and a reamer to do this properly as you need to get the bushings on both sides square and concentric. This is a job I used to do frequently on SU carbs and now need to do on both Zenith carbs on my 235 so I'll have to come up with bushings and a new reamer. I don't know if new throttle shafts are available and it's not something one can fabricate easily. Bushings should not be a problem. It's a ream to fit proposition. If someone knows where to get throttle shafts, I like to know. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Thanks so much for the reply 1Ton. I will be aware now a little more now of the details of this carb now as I go forward. I really appreciate the sharing of your knowledge here.
Troy | | |
