1 members (Otto Skorzeny), 52 guests, and 0 robots.
Topics128,092
Posts1,056,040
Members48,433
#1321364 08/10/2019 8:56 PM
Hi guys, every time I start my car my generator light goes on for a couple seconds but today no light comes on at all. Checked voltage and everything is perfect but that initial generate light does not come on. Should I be co concerned and if so what should I check, thanks?
Sean e #1321369 08/10/2019 9:54 PM
H Online: Content
Change the bulb- - - -it's burned out. The "self test" is the light coming on with the "key on- - - -engine off".
No it’s not, thanks I will try replacing bulb
Sean e #1321490 08/11/2019 11:26 PM
3B Offline
Hy Sean e, please remember to tell us what vehicle you are asking questions about, we give much better answers when we have all the information.
Sean e #1321656 08/13/2019 1:37 AM
Sir Searchalot
Sir Searchalot
He may have a car and is scared to say. One post says 1955 235, another says 57 235. He either has two or does not know what he has or is incognito.
OK sean, come out with it, we will first help you and then you will be banned.
Sean e #1321659 08/13/2019 2:05 AM
Well he used the “C” word in his first post. I guess a 235 is a 235 one way or the other.
Sean e #1321660 08/13/2019 2:06 AM
Sir Searchalot
Sir Searchalot
10-4
Sean e #1321725 08/13/2019 4:00 PM
Sorry for late response but yes it’s a 55 Bel Air with a 57 Cameo engine.
I just had generator rebuilt and light was coming on when I started for a few seconds but no light comes on when I start anymore, thanks guys.
Sean e #1321745 08/13/2019 7:55 PM
Sir Searchalot
Sir Searchalot
Did you check the bulb yet, per your other response? As you know, it's supposed to come on as key comes on and when motor starts it goes off.
I was trying yesterday after work but under the dash is very tight and couldn’t reach to get bulb out unless there is an easier way. I was on floor upside down but there is a lot of wires and hands aren’t small enough,trying not to break anything else. I am not off until Sunday and will try again.
Sean e #1321862 08/14/2019 6:02 PM
Sir Searchalot
Sir Searchalot
The whole "V" cluster comes out the front with just a few screws. Some are on column part of bezel. All while sitting in the seat. No crawling under. There should be enough wire slack to get at bulb. Speedo cable may need unscrewed or it may have slack. In general, it comes out easily or far enough to pop the bulb socket out of it's hole.
Disconnect battery neg BEFORE starting.
Thanks for the great tips
