4 members (baldeagle, Joe H, 78buckshot, Shade Baby), 70 guests, and 6 robots.
Topics128,014
Posts1,055,329
Members48,419
#1321346 08/10/2019 6:43 PM
JD1
Offline
I believe I have a 235 block. Can someone verify by the cast numbers in the picture below?
Thank you.
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
JD1 #1321353 08/10/2019 7:05 PM
That's a cylinder head casting number, not a block number. Post the number stamped behind the distributor, and/or the casting number on the block near the fuel pump. The head number isn't very helpful since they will interchange on several sizes of engines.
JD1 #1321356 08/10/2019 7:24 PM
That is not the head casting code.
Here are the locations of various casting codes on high-pressure 54-63 235/261 engines.
Find and post the following:
1. Engine Serial Number
2. Head casting code
3. Head date casting code
4. Block casting code
5. Block date casting code
We will then be able to help you ID your engine.
JD1
Offline
Here the code behind the distributor.
JD1 #1321368 08/10/2019 9:51 PM
JD1
Offline
Here is the engine serial #:
JD1 #1321376 08/10/2019 11:57 PM
Sir Searchalot
Sir Searchalot
Possibly 1957 235 with 3 speed.
bartamos #1321382 08/11/2019 12:47 AM
JD1
Offline
The engine and the trans are not original. I have a 4 speed with a granny gear and I believe the engine is a 235 but I want to verify it.
Ok. I will look for the block casting code in the morning.
JD1 #1321384 08/11/2019 12:55 AM
Good
And, the head casting code can be seen on the manifold side of the head, outside the valve cover.
JD1 #1321387 08/11/2019 1:25 AM
Zoom his second pic up bigger- - - - - -the stamped number looks like "F I I 7 A" or are the "I"'s actually 1's?
JD1 #1321388 08/11/2019 1:35 AM
JD1,
From the stamped serial number, FII7A, posted a couple messages back, it looks like a '57 serial number ( as Bart' suggested). It decodes to F= Flint plant, 1=January (I and 1's were sometimes interchanged), 17 = 17th day of the month, and A = standard 235. In an earlier posting, you showed the engine casting number - 3837004 - which was a 235 block casting used '55-'57. It's pretty certainly a '57 235, from those numbers.
Would be interesting to know the head casting number - driver's side, near the middle of the head, just outside the valve cover rail.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
JD1 #1321432 08/11/2019 2:19 PM
The casting date above the starter makes this a 1957 engine. And since there are no Captin bars above the starter, that makes this a 1957 235 .
My Blog
