| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | Hi guys, every time I start my car my generator light goes on for a couple seconds but today no light comes on at all. Checked voltage and everything is perfect but that initial generate light does not come on. Should I be co concerned and if so what should I check, thanks? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Change the bulb- - - -it's burned out. The "self test" is the light coming on with the "key on- - - -engine off". Jerry
| | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | No it’s not, thanks I will try replacing bulb | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Sean e, please remember to tell us what vehicle you are asking questions about, we give much better answers when we have all the information. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | He may have a car and is scared to say. One post says 1955 235, another says 57 235. He either has two or does not know what he has or is incognito. OK sean, come out with it, we will first help you and then you will be banned.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Well he used the “C” word in his first post. I guess a 235 is a 235 one way or the other.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | Sorry for late response but yes it’s a 55 Bel Air with a 57 Cameo engine. I just had generator rebuilt and light was coming on when I started for a few seconds but no light comes on when I start anymore, thanks guys.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Did you check the bulb yet, per your other response? As you know, it's supposed to come on as key comes on and when motor starts it goes off.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | I was trying yesterday after work but under the dash is very tight and couldn’t reach to get bulb out unless there is an easier way. I was on floor upside down but there is a lot of wires and hands aren’t small enough,trying not to break anything else. I am not off until Sunday and will try again. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The whole "V" cluster comes out the front with just a few screws. Some are on column part of bezel. All while sitting in the seat. No crawling under. There should be enough wire slack to get at bulb. Speedo cable may need unscrewed or it may have slack. In general, it comes out easily or far enough to pop the bulb socket out of it's hole.
Disconnect battery neg BEFORE starting.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | Thanks for the great tips | | |
